Another valve cover gasket thread - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-06-2009, 07:59 AM   #1 (permalink)
View golfinator's Photo Gallery
Hello from Atlanta. Getting ready to change 97 Avalon rear gasket. Car has 150k mi. Various info says change spark plug tube seals and seal packing on semi-circular plug grooves at cam ends. Any recommendations on doing these items? Also, any recommendations on reuse vs replace egr and throttle body gaskets? Thanks in advance.
golfinator is offline   Reply With Quote
Old 07-07-2009, 03:30 PM   #2 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
For the valve cover gasket, i'd recommend that you use hi-temp RTV on the corners of the cam bearing journals. Pretty much any areas where the gasket is not mating against a flat surface you should use the RTV. As for the TB and EGR gaskets, you don't need to replace them unless they're falling apart, cracked or deteriorated when you take them out. The gaskets aren't that expensive so you may want to replace anyway.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
96paseo is offline   Reply With Quote
