horn button bypass.... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-12-2009, 05:01 PM   #1 (permalink)
View Jagalag's Photo Gallery
Hi, I've been having some problems with my horn button on the steering wheel cutting in and out. I wanted to hook up my own momentary switch, and splice into the factory wiring.
Does anybody have any idea which color wire that I should be looking for? If someone has a diagram, that would be great.
Jagalag is offline   Reply With Quote
Old 07-16-2009, 10:39 PM   #2 (permalink)
Avarollin?
Jigg007's Avatar
Gameroom cash: $132150
View Jigg007's Photo Gallery
Did you verify that it is the horn switch? I had a problem too where my horn would cut in and out. It turned out that the wiring at the disconnect for the horn was really deteriorated. Check that if you haven;t already.
Otherwise I would say the most straightforward way would just tap right off the relay that controls the horn.
Otherwise I think the horn wire may be green/black stripe. Try looking in the driver side kick panel. And maybe you can trace it from the coloum.
Just stay clear of those pesky yellow wires.
Click that cool picture above for my cardomain!
Jigg007 is offline   Reply With Quote
