P0135 Error after o2 Sensor Replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-21-2009, 09:12 AM   #1 (permalink)
View onestandard's Photo Gallery
Hey, all.
Car in question is a 1998 Avalon, 198k miles.
Check engine light came on a while back, and diagnostic computer came up with P0135 error code. Just had a local mechanic put in a new o2 sensor for me last night. He reset the ECU, and this morning on my way into work the check engine light came on again. Stopped by AutoZone, plugged it into the computer, same P0135 error.
Assuming that the mechanic knew what he was doing (he replaced the front o2 sensor before the catalytic converter), anyone have a similar issue or know what it could be?
Fuse maybe?
Thanks in advance for your help.
onestandard is offline   Reply With Quote
Old 07-21-2009, 10:43 AM   #2 (permalink)
Darkside Cut Me!!!
Gameroom cash: $136123
View Hajoca's Photo Gallery
Which of the two senors did he replace? The one next to fire wall?
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 07-21-2009, 10:56 AM   #3 (permalink)
The one at the front of the engine, closest to/facing the radiator.
Old 07-23-2009, 10:34 AM   #4 (permalink)
Darkside Cut Me!!!
Look at:
Oxygen Sensor P0135 Code
The wrong (but soon to be worn out) sensor for P0135.
2004 RX330 Sport
2003 Cam I4 XLE
Old 07-23-2009, 10:44 AM   #5 (permalink)
Thanks for that. Are both sensor 1 and 2 the same model, i.e. do I just need to buy another pre-cat sensor like the one I already had installed?
Old 07-24-2009, 08:56 AM   #6 (permalink)
Darkside Cut Me!!!
Yes as in same type of sensor. Your car has same length of lead wire.
Sensor 2 is downstream or after the cat.
2004 RX330 Sport
2003 Cam I4 XLE
Old 09-17-2009, 09:00 PM   #7 (permalink)
View rajahamsa's Photo Gallery
Hi I replaced O2 sensor bank 1 sensor 1 recently on my toyota avalon 1998 but check engine light came again after 25 miles. How long does it take to go off? any suggestions please????
rajahamsa is offline   Reply With Quote
Old 09-18-2009, 04:36 PM   #8 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $281592
View csaxon's Photo Gallery
Check the code because it may be a different problem.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 10-24-2009, 07:30 PM   #9 (permalink)
View Param's Photo Gallery
Quite possibly the wrong sensor was replaced. When the sensor goes off the first few times, the time or distance between them is as long as 25 miles. Mine had the same interval at the begining. stayed without failure for a day or two. Then came very frequent. What I did was hoping that this is a one time issue, disconnect/connect battery to clear it. After a week, it became that something was wrong. Ran the scanner, & it was that O2 sensor (P0135) died.
Param is offline   Reply With Quote
