Originally Posted by congers1
The PS fluid in my reservoir all leaked out. I added ATF to fill it up and noticed it was slowly leaking in the left side bellows. After reading other past experiences with this issue on this forum I decided to siphon out the ATF and add a 12 oz bottle of Lucas power steering stop and hope for the best. Directions say it may take 2 bottles to work.
Does anyone know how much a Toyota dealer would charge for a steering rack replacement? I'm sure the dealer would charge a $$ premium for the rack.
I had the same issue with my 97 Avalon XLS a few years ago. However PS fluid was leaking out both bellows.
Your rack seals are pooched. You can get replacement seals and try to repair it, or you can get a reman rack.
I went with a reman rack for $99.00 from the Rack Doctor. In the end including duty and shipping to canada, plus shipping out the core I saved $300.00 from a local reman rack. I believe shipping in the states is free from them.
To give you an idea.. Dealer cost including my discount was $1800.00 CDN. Local Jobber was $580.00 CDN.
If you do it your self, watch out for the rear O2 sensor. It is in the way and difficult to work around. I pulled my rack from the drivers side, and it was fairly straight forward to do.
The reman rack comes with new tie rod ends. You will need to do a wheel alignment afterwards.
Make sure you get your measurements on the tie rod ends pretty close before you install it.
The whole job was about 4-5 hours to do.
