Well, for someone that doesn't know much about cars, it might be a little as it requires taking of some of the panels and disconnecting cables. Not very complicated, just make sure to keep track of screws! The panels are a little hard to come off, but don't need pry bars...maybe a simple flat head screw driver.
I'm doing this mostly out of memory, but it should be pretty accurate.
4x 194 bulbs for gauges
2x 184 bulbs for the door courtesy lights
2x 4mm NeoWedge for ECT/AC (I think with these, though, air recirc will not turn on as it uses a diffuser)
3x 74 bulbs for the temperature dials
1x DE3175 for the dome light
I don't know how many bulbs you need for the electronics temperature controls as I don't have that version of the Avalon. Maybe someone else on here can share the knowledge?
I do warn though, that since LEDs aim light and do not just spread it, you'll get spots that are brighter than others. For the air recirculation buttons, it will probably not get lit up because the diffuser is on the side of the bulb, and LEDs don't spread light that much (at least not the 4mm ones). I think the electronic temperature controls have the same issue.
