You can get most of the code descriptions here: Click me If you go to that webpage, they give possible causes for each code.
P0300 = Random/Multiple Cylinder Misfire Detected
P0125 = Insufficient Coolant Temperature for Closed Loop Fuel Control
P0171 = System too Lean (Bank 1)
P1135 is manufacturer specific, so it's in a little different place on that same webpage.
P1135 = Air/Fuel Sensor Heater Circuit Response. (Bank 1 Sensor 1)
I'm no expert (there are plenty of folks on this board who are), but I'd say you've got a few problems:
1) A bad O2 sensor in the rear bank's exhaust manifold, the one next to the firewall. I am certain of that.
2) Either a bad coolant temp sensor, or the cooling system thermostat is stuck open. Does the temperature gage on the dash register a normal operating temp? If not, then it's most likely the thermostat.
3) The misfiring could be bad spark plugs. If they've never been replaced, do it. A lot of other things could cause misfiring, but that's where I'd start because it's due for it anyway.
Reason: Plug wires not normally a prob on the 1MZ motor.
