HID projector retrofit??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-22-2009, 10:21 PM   #1 (permalink)
TTownEP3's Avatar
View TTownEP3's Photo Gallery
Question HID projector retrofit???
Has anyone here done a projector retrofit for HIDs?
TTownEP3 is offline   Reply With Quote
Old 09-23-2009, 04:00 AM   #2 (permalink)
Gameroom cash: $254367
View sarsman45's Photo Gallery
I dont think anyone in this forum has. It really depends on your car. I know that retrofitting is great and all (safer too), but the first gen Avalon (before she died) had very good cut offs stock. Just don't forget to adjust those lights if you do go stock though. Blinding people is a no-no.
'02 Toyota Tundra iForce V8 TRD AC THUNDER "FRACKING" GREY METALLIC 97000 miles
sarsman45 is offline   Reply With Quote
Old 09-23-2009, 09:51 PM   #3 (permalink)
TTownEP3's Avatar
Well I'm rounding up parts for MY retrofit on a Civic Si. But it got me thinking about my gf's Avalon, and whether or not anyone on here had done it. I saw several people had thrown in a PnP kit, but didn't see any with a projector retro. If it was done, it would probably take some custom lens work too, in order to get rid of the fluting, or retro-ing some post 98 headlamps.
Old 09-28-2009, 09:53 AM   #4 (permalink)
View mmejia's Photo Gallery
I haven't done it, but have been thinking about it. The easiest and cheapest thing to do would be to go ahead and buy some fog light projector (P6 on ebay I think are the common ones) and modify the headlight housing to take those. I believe the P6 have angel eyes/halos, so big plus there.
If you want to go all out, you can get the TSX projectors and whatever lenses/shrouds you want and try to mount those on. The hardest part is just getting the alignment right when you're cutting up your housings.
mmejia is offline   Reply With Quote
Old 10-24-2009, 10:39 PM   #5 (permalink)
View Param's Photo Gallery
Cleaned the lens with wet sand paper (1000 grit, 2000grit) & then with tooth paste. Replace low beams(HB4 9006) with Toshiba HIR 9012. What a difference!! Seeing the road a lot better in dark.
Sand papers few dollars.
Tooth Paste
Two HIR $80 (including taxes in Canada
Param is offline   Reply With Quote
Old 10-24-2009, 11:58 PM   #6 (permalink)
TTownEP3's Avatar
I put Infiniti FX BiXenons in my car. It was really not hard. It did take several days, because I didn't plan ahead and order the correct parts, but they turned out really good.
Old 03-22-2010, 09:44 PM   #7 (permalink)
View stunt101's Photo Gallery
Tooth Paste
Did you have to modify anything to fit with those bulbs?
stunt101 is offline   Reply With Quote
Old 03-26-2010, 11:21 AM   #8 (permalink)
on full afterburner
Gameroom cash: $1347897
Old 03-27-2010, 08:44 AM   #9 (permalink)
View ImDisaster's Photo Gallery
The HIR's are about twice as bright as the stock halogens and much better than installing a PnP HID kit (more even light where it is supposed to go.)
Here is a source for the bulbs.
http://store.candlepower.com/hirlighting.html
Here are the instructions for modifying the base.
http://store.candlepower.com/mohirbuba.html
ImDisaster is offline   Reply With Quote
Old 04-06-2010, 06:24 PM   #10 (permalink)
TTownEP3's Avatar
Originally Posted by PhatRoyale View Post
I didn't adjust the white balance on my camera for this one, so it looks really yellow and warm. It's really just white. Also, I adjusted them a bit more for the aim after these were taken.
