1997 Avalon Headlights wont turn off even when switch is off - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-09-2009, 12:58 PM   #1 (permalink)
View DONJOHN's Photo Gallery
Question 1997 Avalon Headlights wont turn off even when switch is off
They ran a diagnostic test and said it is the relay switch, is this expensive and can it be put in easily????
DONJOHN is offline   Reply With Quote
Old 10-09-2009, 01:12 PM   #2 (permalink)
View mmejia's Photo Gallery
Depends on which one you buy. I think they run from $10-$50. I'm not sure how much the relay for the headlights would run, but it shouldn't be that bad. It's super easy to put in...just unplug old one, pop in new one.
EDIT: I did a little work for you. $11 from Rockauto.com
http://www.rockauto.com/catalog/rafr...272664k1481594
mmejia is offline   Reply With Quote
Old 10-09-2009, 06:49 PM   #3 (permalink)
Do you know where it is located??? do they have to remove the whole steering column??? or is it easier?
Old 10-09-2009, 10:04 PM   #4 (permalink)
The headlight relay should be in the main fuse box in the engine compartment. I'm pretty sure the fuse box cover has a little diagram showing you what each relay does. You should be able to just pull the one in there and pop in the one that you bought.
