Originally Posted by eldiaoble
I have the exact same problem only with my rear passenger side door. It acculmulates so much water that when I close the door you hear the slish and sloshing. What I do is take out the two screws at the very bottom and the water slowly drains. I tried putting eletrical black tape on the window thinking it was going through the rubber seal and the window, but it turned out it didnt work.
I have been searching for an answer for a while but cant find it hopefully someone else on this forum will be able to help us out.
Toyota's sloppy job of under door molding installation is the cause. Metal sheet holes and Molding holes DON'T align on any of the doors. Drill holes on molding to match the door shell will solve the problem. Ist time I had problem was right after krown rust protection. I guess that the grease blocked the only available small gap & caused it to collect water.
Collecting water is one problem, but the bigger problem I had was in Winter(live in Toronto), car windows inside filled with a a sheet of ice. Heater, defogger, A/C, etc.. melt the ice but fogg the windows. This year I drilled holes on door molding to align drain holes, & hope this will take away the problem.
