Can someone tell me how to get the CEL to blink using a Fused Jumper wire - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-09-2009, 05:57 PM   #1 (permalink)
View Jason1987's Photo Gallery
My friend has a 96 avalon, OBD1. I found a site describing what i want to do on a corolla OBD1 but it's not the same for the avalon. Does anyone know which pins in the DLC to connect the jumper wire to make the CEL Blink? PLease and thank you
Jason1987 is offline   Reply With Quote
Old 12-10-2009, 01:07 PM   #2 (permalink)
Gameroom cash: $121830
View gideon1331's Photo Gallery
All Avalons are OBDII.
It came on the 95's (at least my mother's 95 is OBDII) and was required by law in 96.
Just go to AutoZone or other parts store and they should plug in their reader and give you the code for free.
Toyotas in the family/next of kin:
1982 Corolla Wagon, 1989 Corolla DX, 1991 Previa LE, 1993 Previa LE,
1993 Pickup, 1994 Corolla DX, 1995 Avalon XL, 1996 Camry XLE, 1998 Avalon XL,
1998 Sienna CE, 1999 Camry XL, 2000 Camry XLE, 2002 Tundra, 2003 Tundra,
2003 ES 300, 2004 Camry XLE, 2005 Tacoma
gideon1331 is offline   Reply With Quote
Old 12-10-2009, 01:15 PM   #3 (permalink)
Autozone only carries the OBD2 scanners. Atelast the one that i live next to anyway. I own a OBD2 scanner myself. The car is a 96 but it is OBD1
Old 12-10-2009, 01:24 PM   #4 (permalink)
It cannot have OBDI. The Avalon was launched with OBDII, and in fact the 94 V6 Camry and Lexus ES300 that the Avalon took nearly all its parts from had OBDII.
Old 12-19-2009, 11:18 PM   #5 (permalink)
View GOT BOOST's Photo Gallery
The Avalon is OBDII Compliant. The access port is in your fuse panel on the drivers side. Pull the fuse panel and the access port is at the top of the fuse box.
Are you trying to pull non engine codes? Are you looking for the data link connector? You need a jumper wire to access the ABS, Trac codes, etc on that one. That connection is right above the ebrake pedal. That is the DL2 connector. That will NOT access the engine codes.
EDIT:
There is also the DL1 connector in the engine bay. It is attached to the intake plenum right above the intake cam. Jump wires TC and E1 to pull the ABS/Traction Control/Cruise control and Airbag codes.
You will need to remove the metal clip that is installed in the connector to read the codes. You will know what I mean when you see it.
To clear those codes turn the ignition to the on position pump the brake 8 or more times with in 3 seconds to wipe the codes.
Hope this helps.
For the Check Engine codes, you will need to pull them with the OBDII code reader and clear them with the reader.
GOT BOOST is offline   Reply With Quote
Old 12-20-2009, 11:46 AM   #6 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $281592
View csaxon's Photo Gallery
OBDII JASON!! LISTEN TO YOUR ELDERS!
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
