Spark plugs inside; under the intake thinge - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-26-2009, 09:21 PM   #1 (permalink)
View msrdude's Photo Gallery
I have a 96 Avalon XL. I replaced the 3 spark plugs outside, which were easy. I am having trouble replacing the other 3 spark plugs inside because the intake thinge is blocking my way. I do not want to remove the intake thing because there is too many things and bolts to remove. I heard that you can replace the spark plugs without removing the intake thing. I am not sure how to do it. Anyone know how to do it? Thanks
Cars that I own:
1996 Toyota Corolla DX
1996 Toyota Camry LE
2007 Toyota Camry SE
msrdude is offline   Reply With Quote
Old 12-27-2009, 09:12 AM   #2 (permalink)
View toyomoho's Photo Gallery
Suggest a TN history search of posts and checking the internet as others have had this issue with suggested solutions posted. The Avalon uses the same engine as Camry with V6 option and a few other Toyota models. Thus expand your search beyond Avalon.
There are is special socket wrench tool out there to do the job. Others have used a combination of swivel joints and extensions.
Old 12-27-2009, 05:40 PM   #3 (permalink)
kevdude's Avatar
View kevdude's Photo Gallery
Yep, a couple of extensions and a swivel joint will do the trick just fine. No need to remove the manifold. Just takes a little bit of patience.
97 Avalon XL, 198,000 miles and still going!
06 Solara SLE convertible
kevdude is offline   Reply With Quote
Old 12-31-2009, 11:27 AM   #4 (permalink)
View leadsled toy's Photo Gallery
It sounds as if our poster might not know what swivels and socket wrenches are based upon his/her description of the intake manifold as an "intake thinge".
If that is the case, please take it to a mechanic or a friend familar with automotive maintenance. Otherwise, the job is simple enough if the right commonly available tools are used and you have familarity with how to use them. Patience is then the key.
1998 Toyota Avalon XLS
160k miles and counting w/o major maintenance required.
Pads/ Rotors/ Timing Belt/ Plugs Only!
leadsled toy is offline   Reply With Quote
Old 12-31-2009, 06:55 PM   #5 (permalink)
View fourwheeler's Photo Gallery
I believe a wobble extension set is the proper tools you are looking for.
fourwheeler is offline   Reply With Quote
Old 01-15-2010, 02:34 PM   #6 (permalink)
View miflox's Photo Gallery
Msrdude; Do you have a mechanically-inclined friend or neighbor that can help you? In addition to getting the right plugs + tools, I would suggest that you:
1)Double-check the gap on the new plugs. Gapping tool is cheap.
2)Lightly coat the spark plug threads with anti-seize. Available at parts store.
3)Coat the inside of the spark plug boot with dielectric grease.
4)Don't overtighten the spark plugs; you don't want to strip the threads.
miflox is offline   Reply With Quote
Old 01-25-2010, 08:07 PM   #7 (permalink)
View blkavalon's Photo Gallery
i was able to do mine with the right size extension. didn't remove anything. surprised how easy it was. make sure to use NGK two tip plugs.
98 Avalon XLS, 91 Camry, 78 Corvette, 92 Saab 900,
05 Yamaha R6 Raven, 81 Suzuki GS 650L,
blkavalon is offline   Reply With Quote
Old 01-27-2010, 01:14 AM   #8 (permalink)
View 1990rolla's Photo Gallery
theres no need to gap them if you get the toyota recommended dual electrode spark plugs
1990rolla is offline   Reply With Quote
Old 08-24-2010, 09:24 PM   #9 (permalink)
View allenjh's Photo Gallery
Thanks
Thanks for the info. I just changed the plugs on my 99 Avalon Platinum Edition. The original plugs had 147,000 miles on them and they still looked good. My arm was almost too big to get into the tight spaces to do the rear plugs but perseverance paid off. Thanks for the great information on tooling.
Thanks, Jim
99 Avalon Platinum Limited Edition
allenjh is offline   Reply With Quote
Old 08-24-2010, 09:58 PM   #10 (permalink)
Banned
View The Digital MagE's Photo Gallery
spring for the bosh iridium plugs, and never change them again.
these work super on my avvy. i torqued them to 30 ft lbs. used pencil lead for anti-seize. i did this during an engine swap so have no idea of how hard it is to cheat the plenum problem. now i'll never know!
The Digital MagE is offline   Reply With Quote
Old 08-24-2010, 10:14 PM   #11 (permalink)
Avy
Gameroom cash: $821455
View pmesfun's Photo Gallery
Gen1
Stay away from Bosch, just use oem(denso) or ngk. Better just to stick with oem to ensure no problems will arise.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is online now   Reply With Quote
Old 08-24-2010, 10:38 PM   #12 (permalink)
I used the NGK dual electrode plugs. They are in now and I am sure as hell not going to change them for another brand. I'm confident they will be fine. I am giving the car to my son and he'll get plenty of miles out them.
Old 08-25-2010, 12:11 AM   #13 (permalink)
Avy
Gen1
Good stuff, one question though. Were the original spark plugs you pulled dual electrode?
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 08-25-2010, 05:30 AM   #14 (permalink)
Yes, the original plugs were Denso dual electrode plugs. My owner's manual says to only use dual electrode plugs.
Old 08-25-2010, 10:28 AM   #15 (permalink)
Gameroom cash: $301725
View artbuc's Photo Gallery
Thanks, Jim
I also have the 99 Platinum. Just did my plugs a couple months ago at 99k. Used NGK double ground just like the originals. I would love to replace my hub caps but can't find them anywhere. Do you know where you can get them?
PS Sorry to hijack this thread but I don't see too many Platinum posts!
artbuc is offline   Reply With Quote
