Radiator repairable? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-04-2010, 12:31 AM   #1 (permalink)
View msrdude's Photo Gallery
I have a 96 avalon and it is leaking coolant. Almost all of the
coolant reservoir is empty in 2 to 3 days. I found a crack on the
radiator that looks like hairline crack. The crack is
difficult to notice and i tried plastic epoxy but it did not work
maybe because the crack is too small. But i do drive a lot so it makes
sense that the coolant is leaking out a lot; even with a little crack.
There is no other noticeable leaks around the radiator or the
reservoir tank.
I heard that you can use a tie strap and melt it on the crack on the
radiator. The radiator and tie strap are made with the same material.
Is that true? Is there any other way to repair this small crack
because it seems like a waste to replace the radiator
Cars that I own:
1996 Toyota Corolla DX
1996 Toyota Camry LE
2007 Toyota Camry SE
msrdude is offline   Reply With Quote
Old 01-04-2010, 07:45 AM   #2 (permalink)
View blkavalon's Photo Gallery
ther is a clay type of stick that you can buy from advance auto specialy for radiators and gastanks. i highly recomend you to change the radiator. any repairing will fail someday and you dont want that radiator replacement escolate in to a headgasket repair. $200 for a peace of mind.
98 Avalon XLS, 91 Camry, 78 Corvette, 92 Saab 900,
05 Yamaha R6 Raven, 81 Suzuki GS 650L,
blkavalon is offline   Reply With Quote
Old 01-04-2010, 12:28 PM   #3 (permalink)
Gameroom cash: $818201
View zythr's Photo Gallery
Like Bk said just replace the radiator. You could be on the highway going 65 and have all your coolant leak out and be stranded on the highway, not worth the risk
zythr is offline   Reply With Quote
Old 01-04-2010, 01:02 PM   #4 (permalink)
View toyomoho's Photo Gallery
Concur. The repair could fail or the radiator now fail much worse at another location. This has happened!
Some radiator shops may be able to replace the tank but compare the costs with a new radiator.
