Trac /mpg question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-06-2010, 06:56 PM   #1 (permalink)
View kmarx54252's Photo Gallery
Trac /mpg question
OK
I got some good advice on my first post - Thank you
so I'm going to try again,
I got my 97 XLS with around 100k, have 120k+ on it now. So far I have serviced the exhaust flex pipe & frozen rear calipers. (calipers replaced 1 week ago with old torn boots on pins. new pins & boots ordered and will be installed as soon as received, calipers functioning properly now)
Four weeks ago I hit a large pot hole and my trac off light came on, I noticed no discernible handling difference. but my gas mileage suddenly dropped form 25 mpg to just under 20 could this be caused by the trac system?
For information these items also need to be fixed - leaking PS pump. rear valve cover gasket and cat converter (cat converter code came on right after the flex pipe was repaired over 2 months ago)
I consider myself able to preform most motor and chassis repair but not a diagnostic wiz and I appreciate any information as this car is quite new to me.
Keith
kmarx54252 is offline   Reply With Quote
Old 01-06-2010, 07:11 PM   #2 (permalink)
Gameroom cash: $818201
View zythr's Photo Gallery
All trac light being on causing lower fuel mileage? Probably. Maybe you should check to see if your all trac was not damaged, since hitting the light to come on? Have you been driving it with it on on dry pavement? I don't know if the system is designed to be used on dry pavement. Good luck
zythr is offline   Reply With Quote
Old 02-03-2010, 12:29 PM   #3 (permalink)
View blkavalon's Photo Gallery
after driving for a week in snow my Trac off light came on and my battary died yesterday and when i removed the battery to recharge i guess it reseted and everything is back to normal.
98 Avalon XLS, 91 Camry, 78 Corvette, 92 Saab 900,
05 Yamaha R6 Raven, 81 Suzuki GS 650L,
blkavalon is offline   Reply With Quote
