You sure it's not a burning oil smell? A fairly common problem with these cars is leaking valve covers. The leaking oil runs down onto the exhaust and burns much like you described; can't smell it if you're moving, but comes thru the vents when you stop. Usually it's the rear bank of cylinders that are the culprit because they're tilted back so far. It's difficult to get a good look at it because it's so buried back behind everythin.
