96 avalon dome light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-29-2010, 01:30 AM   #1 (permalink)
View ymp525's Photo Gallery
Hey guys, my 96' avalon's dome light has just stopped working recently. I changed out the bulb but still no light comes on. Any help as to how i can fix this? Thanks
ymp525 is offline   Reply With Quote
Old 01-29-2010, 09:45 AM   #2 (permalink)
View bigkew's Photo Gallery
Dome Light
I had the same problem with my 97 Avy, I used a multimeter to check for voltage at the contacts to the bulb and cleaned all the connections on the assembly and it has been working since. You will also need to pull out the assembly and check the connections on the back. The first thing you should have checked is the fuse.
Hope this helps.
bigkew is offline   Reply With Quote
Old 01-30-2010, 08:58 AM   #3 (permalink)
kevdude's Avatar
View kevdude's Photo Gallery
Besides checking the wiring/fuses, wiggle the bulb you installed. The recepticle/bulb isn't the best design, and mine always came back on after I played with it for awhile.
97 Avalon XL, 198,000 miles and still going!
06 Solara SLE convertible
kevdude is offline   Reply With Quote
