With no movement(parked) and using a couple friends bounce the front end up and down and watch the inner fender and suspension parts that you've listed..This is a rough suspension test..Then using a helper on a parked car (key forward engine off) cycle steering wheel quickally back and forth,only far enough to make the steering parts hardly start to move..This is a rough steering test again look under the car on both sides look at tierod ends, rack ends or noises in the strut mount, look for the part that is moving with play ..Also cycle wheel all the way back and forth check for clearence of inner fender or any other tire obstructions.. Engine mount test, with vehicle running, hood open,foot on brake, shift from D to R.. Watch the engine as this is done look for engine movement, a very little movement is normal excessive engine movement can also make awkward noise in the exhaust and suspension parts.. GOOD LUCK..
95.5 Tacoma 2.7 300,000
91 Corolla 1.6 180,000
96 Avalon 3.0 190,000
95 Ford Aspire 1.3 125,000
