Best place to get suspension parts... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-25-2010, 01:55 PM   #1 (permalink)
View BB2001S4's Photo Gallery
HI,
Need some guidence to where I should pick up or order some suspension parts for my 96 Avalon?
So far (from doing a quick search) I should replace the struts and mounts. Currently I had installed KYB struts (love them by the way) and was wondering if anyone know where is a good place to pick them up?
Never really replaced the mounts...so what does TN recomend???
Appreciate any help from some of the regualars and gurus here
Thanks,
Tim
BB2001S4 is offline   Reply With Quote
Old 02-25-2010, 09:33 PM   #2 (permalink)
View ImDisaster's Photo Gallery
I bought my suspension parts from two different places on the web. Colonial, and ToyotaPartZone. I like the schematics at TPZ. Stick with the Toyota OEM mounts. I haven't heard anything good about other options. If you check the schematics at TPZ and the part list you can see parts that have changed from the original, most likely to improve their performance.
ImDisaster is offline   Reply With Quote
Old 02-26-2010, 05:02 PM   #3 (permalink)
View fourwheeler's Photo Gallery
If you search this site, everyone will have an opinion on which shocks/struts are best. Overall, KYB gets the most positive feedback and the most recommendations. Personally, when I do mine in the spring, I'll probably get the KYB's from either rockauto.com or Advance Auto Parts. Advance has coupons every couple of days if you sign up for their e-mail offers.
Let me know how it goes, I'm a couple of months behind you. Good luck
Russ
fourwheeler is offline   Reply With Quote
Old 02-27-2010, 07:33 AM   #4 (permalink)
Russ
From a durability standpoint, the Tokico's, are higher rated, (they will last longer) however they are a little stiffer than the KYB's. As it is, the KYB's will firm the Avalon's ride up a little bit. Because I'm used to, and prefer a firmer ride, I bought the Tokico's and Vogtland lowering springs. If you decide to get replacement springs make sure they are from a reputable supplier. Some of the cheaper springs (like Intrax) will sag. The better ones are heat treated, shot peened and tempered properly. The Vogtlands are made in Germany. Eibach's are also supposed to be good.
Per the Vogtlandsuspension website.
"Vogtland Lowering Sport Suspension Springs are made in Hagen-Hohenlimburg, Germany and TUV tested with original equipment manufacture ( OEM ) quality and carries a Limited Lifetime Warranty. Springs are produced using special oil tempered spring alloys, using the cold coiling process machinery developed by Wafios Machinery Corporation. This achieves low spring weight with high material strength and the desired effect of uniformly reducing the un-spring weight of the vehicle by optimizing the handling performance characteristics. Suspension springs are tempered, shoot peened and preset to ensure a consistent supension function and ride height. Low grade value brand springs will loose length with dynamic inpact, but not Vogtland. Vogtland Sport Lowering Springs and suspension are engineered for each make | model using stock Shocks."
Old 02-27-2010, 10:20 AM   #5 (permalink)
Frankie Avalon
KeepItSimple's Avatar
View KeepItSimple's Photo Gallery
Any good struts made for the Avy that don't have a firmer ride?
KeepItSimple is offline   Reply With Quote
Old 02-27-2010, 05:14 PM   #6 (permalink)
I recall reading there are Monroe's that are pretty soft...inexpensive too. Monroe sells kits that fit many different cars.
