I had the IAC out of my Camry a while back for cleaning; completely disassembled it. When I went to start it, it wouldn't fire at first. Then I started flooring the gas pedal and it started but died immediately if I let up on the gas. It would then start and run a bit as long as I was giving it some throttle.
It seemed like the computer controls needed to re-cal the IAC. It took half a dozen re-starts before it started behaving normally.
