Need help regarding ABS speed sensor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-14-2010, 03:17 PM   #1 (permalink)
View Alexw08's Photo Gallery
I need help replacing my left rear abs speed sensor. I checked my car and it turns out that the wire of the speed sensor on the suspension has been cut by someone, and it is missing a piece of the wire. How do I install the sensor? What parts should I remove, what is the step by step procedure? I hope someone can help me. Thanks!
Alexw08 is offline   Reply With Quote
Old 04-15-2010, 06:49 PM   #2 (permalink)
View 05DCLB's Photo Gallery
Being in the rust belt the old sensor will most likely break off in knuckle. Dig,chisel,pry old pieces out. YOU MUST get all old sensor/rust out before new one will fit all the way in. Be cafefull not to snap little 6mm bolt too.
05DCLB is offline   Reply With Quote
