2 concerns - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-02-2010, 03:15 PM   #1 (permalink)
View karl_karl's Photo Gallery
2 concerns
Does anyone know what could be causing a "popping" sound by my passenger side tire a few times a day. Is the symptom of a bad ball joint? I checked the boot and it wasn't ripped....
Also, I just switched from conventional oil to Quaker State horsepower synthetic (because it was on sale). My car didn't leak oil before, should I run into any problems from the switch...what is the consensus out there?
Thanks,
Karl
karl_karl is offline   Reply With Quote
Old 05-02-2010, 06:12 PM   #2 (permalink)
View systematic's Photo Gallery
u shouldnt have any problems with the oil switch, as for the popping... im not mechanically inclined enough to tell u
systematic is offline   Reply With Quote
Old 05-02-2010, 08:23 PM   #3 (permalink)
View robcam13's Photo Gallery
oil switching is a myth. you wont have any issues as long as you use the recommended grade. your noise is probably your upper strut mount or possibly inner or outer tie rod going bad. have someone turn the wheel and hopefully you can hear where the noise is coming from.or jack the front of the car up and check for excessive play in the tie rods and turn the wheel but im guessing its a strut plate. if you need more help let me know
robcam13 is offline   Reply With Quote
