I have a 1997 avalon with no spark at the coils. it's got a 3.0l 1mz in it.
I've replaced everything related to the ignition system except the crank sensor. when I check the resistance of the crank sensor it's within the limits for 1 second,then the reading disappears. no matter how many times i check it i get the same reading for 1 second.
This all started with a "no-start"condition and 1 code ...po340- camshaft sensor. I replaced the cam sensor, no change.. I verified the timing marks 5 times, it's dead on. I used my All-Data to trouble shoot the wiring for the cam sensor, checked for continuity and shorts, nothing unusual . some one suggested iron filings on the sensor, so i pulled the valve cover to clean it. I also checked to make sure the cams were spinning. I've checked for power at the coils and power at the igniter. I've replaced the computer, the coils and the igniter. And as far as i know there was no security system on avalons in 1997.....I've hit a brick wall and need some fresh eyes.... and this All-Data manual leaves a lot to be desired
