Originally Posted by NRecob
My post before didn't have any photos--i was referring to a previous posts links to photos of the doors/plugs (it was a good shot for the overall door--but for the plugs not so great--I found the plugs after going over the door inch by inch). In any event, I'll shoot some photos here in a bit and get them uploaded (I'll have to re-remember how to do that. lol).
Finally, no, you don't have to take the door apart to get to these plugs! (at least not on my '95 Avalon XL you don't). Again, I'll get the photos up shortly--pull these plugs and let the water drain out--I even shook the doors back and forth to get all the water out I could and I even left the doors open for a while after. I never did reinstall the plugs (they're in my ashtray). You may or may not want to reinstall yours....
HTH
On the left rear door I pulled back the very bottom strip of weather stripping on the far right — it didn't come off, it just moved out and up a little — and the water started to flow out pretty quickly. Because a little water was coming out below the paneling, I unscrewed the bottom screws and lifted it up a bit — not a lot of water, but when I ran my finger under it I just got a lot of slimy crap. Here's a photo of what I pulled back on the that door:
Did the same thing with the strip on the right door — they both only pulled up closest to the car/door hinge. I pondered attempting to remove that little circular thing, but wasn't sure how to do it/how to put it back on, so I refrained.
Anyway. That drained both of the doors. Temporary fix, but I wouldn't like it to happen in the first place.
In the process I found water coming from a peg/plug that was also holding the weatherstripping to the door — I removed it but I don't think I should remove the plug since it's needed to hold that piece of strip on. Photo:
