Power Windows - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-01-2010, 09:08 PM   #1 (permalink)
View adm91's Photo Gallery
Power Windows
It looks like my power windows are on the way out ... I've seen it coming but tonight the driver's window finally got stuck 4" after it started going up. I gave it a little push up and it tugged along up, but it wasn't very pleasing. The other windows seem to be ... fine, I guess. Not as bad as the driver's window.
I've read a bit and it seems like a common problem but haven't really seen any fixes.
Any ideas?
adm91 is offline   Reply With Quote
Old 06-01-2010, 09:53 PM   #2 (permalink)
View CDJr's Photo Gallery
About the only way to figure it out is by taking the panel off and lowering and raising it cuz it could be a loose bolt allowing the glass to bind up in the channel, it could need to be re-greased, or it could be the motor binding up. If you can move the glass at all front to back, its likely something loose that needs to be realigned and tightened. But observing it in operation is about the only way to figure it out. Hope this helps...
CDJr is offline   Reply With Quote
