1995 Avalon over heating any ideas on what to fix?
I have a 1995 Toyota Avalon. With 130,000 miles. I live in Houston Texas it is really hot and humid here.
Symptoms:
From cold start car will warm up to normal temp in about 3-5 mins. It will hold that temp steady for another 3-5 min then skyrocket way above the H with in 30 seconds. When it over heated a check engine light came one. Code p0115 engine coolant sensor. The heat caused a 1 inch crack in the radiator and a small hole in the coolant reservoir.
What we have replaced so far:
Engine coolant sensor
Radiator
Thermostat (old one seemed to open same time as new one in boil test but we replaced it anyways)
In the process of changing:
Water pump (Old one spun fine and looked ok but we replaced anyways since we had it all torn down)
Timing belt
Still have yet to see if that fixed it. However the water pump seemed fine....
Any Ideas would be greatly appreciated.
Questions:
Could the hole in the top corner of the radiator fluid reservoir cause it to over heat?
Symptoms:
this is the way an engine acts when it is very low on coolant... and possibly getting exhaust in the cooling system. i dunno how prone to blowing head gaskets the 3-0 is but i have lived in houston and i know lots of cars need that kind of repair, down there.
Radiator
Timing belt
Questions:
Well i finally got the block test to work (had to really lower fluid to keep it from overflowing) and it looks like it is a blown head gasket.... Anyone know how hard a job that is or what it costs?
I wish I am wrong. I might take it to a shop just to have it confirmed, because as it sits if the head gasket is blown the most I have been able to get someone to offer for it is 300 bucks...
The block test is what confirmed it was a head gasket along with having replaced everything above.
The best way of determining a blown head gasket is with a cooling system pressure gage/pump
it only takes a minute to find out,
I think you can borrow one from vato zone or orielys , you will need the small "jap car" adapter
Start with a cold engine and a FULL cooling system, install pump in place of the radiator cap,
start the engine, a car with a blown head gasket will build up pressure within seconds, you will see the gage shoot sky high, and I hope that is not your case,
if the pressure builds slowly and is steady (and it climbs high), chances are your radiator is fubar, that is what brought you to the existing condition.
an engine with a blown head gasket MIGHT build pressure within seconds. it might need to get to temp before it begins to leak exhaust gas into the coolant. it might not build pressure at all, leaking oil into the water (or vice-versa) instead... or into a cylinder. it might leak compression between cylinders, or even to the outside air.
look - if your engine sprays coolant out of the radiator cap, odds are it has a blown head gasket. it has to get might hot before it will boil over and, with antifreeze in it, REALLY hot!! smell the cap. if it smells like exhaust, there you are. they even make a tester that looks for exhaust at the cap.
Thanks guys for the input. The block Tester changed colors with just 2 pumps of air. That is almost as fast as putting it up to the exhaust pipe. The head gasket is blown.
The question is should I sell it for scraps a guy came and looked at it and said 200-300 bucks.
Should I spend a few weeks and change out the head gaskets and then sell it? (A head gasket kit is about 350)
I ended up buying a used Prius, so I don't need the car any more I am just trying to get the most money i can out of it.
there's an outfit right there in dallas that sells jdm engines. i bought an enginge and trans for $1,250.00 the trans had a bad solenoid and the arab dirtbag that runs the place blew me off when i told him it was not good. i'm gonna do a chargeback on my visa card...
so it's a crapshoot. but odds are you'll win.
jdm engines come from cars that are junked in japan with 35-50,000 miles on them. well worth getting!
