Transmission fluid reading very high - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-16-2010, 09:52 PM   #1 (permalink)
View prinzem3's Photo Gallery
Hey guys
So I just got myself a 96 Avalon-xl with 74k miles and decided to do some fluid changes. When I got to the tranny fluid, it read way over full. About an inch above the hot line, but the old fluid was still red. I proceeded to drain and fill the fluid and it still reads high.
The car was up to temp and i did shift through all gears and the fluid was checked with the car on in P.. Am I missing something or is it sooooo overfilled?
I will drain it out again tomorrow to see why the reading is so high
Any suggestions would be appreciated
Thank you
-Vince
prinzem3 is offline   Reply With Quote
Old 06-16-2010, 11:04 PM   #2 (permalink)
View robcam13's Photo Gallery
is it running when you check it. it should be. also pull the dip sick wipe it off then check it.
robcam13 is offline   Reply With Quote
Old 06-16-2010, 11:18 PM   #3 (permalink)
did all that
-vince
Old 10-26-2010, 03:35 AM   #4 (permalink)
View ImDisaster's Photo Gallery
Mine read high too, when I got it, at 85K. I never drained any oil and it never gave me any troubles till the oil started leaking through the cork gasket at 114K. At that time the oil looked terrible (and still read high.)
ImDisaster is offline   Reply With Quote
