If you have a speaker mounted in the molding of the center rear brake light then you have the 7 speaker system.
If you can't find an oem amp, don't worry, just buy a 5 channel amp. These 5 channel amps can actually improve your sound quality because like ChunkyWolf said, the oem amps aren't very impressive. These amps have 4 channels for the cabin (front right, front left, back right, back left) and one for the subwoofer. This covers all 7 of your speakers, since the back doors have 2 speakers a piece. These can be had off ebay for less than 200 bucks or Crutchfield for 350 or more. But 500 dollars for a Boston Acoustics amp (great brand) is less than the oem and will probably yield better quality and more options.
http://www.crutchfield.com/g_347150/....html?tp=35808
But your head unit does have a 4 channel amp built in, which might be enough to power all 7 of your speakers. The 7th speaker (the subwoofer) might just be wired into all 4 channels which means you don't even need an oem replacement amp. The head unit will probably provide better sound than the oem amp.
