ball joints ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-24-2010, 08:19 PM   #1 (permalink)
Banned
View The Digital MagE's Photo Gallery
ball joints ?
even though i replaced the struts, springs and sway bar bushings i'm still hearing an annoying rattle type of sound in the front.
the chasis has 160,000 miles on it. should i be thinking about ball joints?
The Digital MagE is offline   Reply With Quote
Old 06-24-2010, 11:10 PM   #2 (permalink)
Work In Progress
SyStEmOfEvIl's Avatar
View SyStEmOfEvIl's Photo Gallery
Did you replace the strut mounts as well? I have read that those are sometimes the noise makers. If you have, than i would say that the ball joints would be next on the list. If not that, your wheel barings.
96 Toyota Avalon XL
SyStEmOfEvIl is offline   Reply With Quote
Old 06-24-2010, 11:40 PM   #3 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $353553
View BMR's Photo Gallery
^What he said. Also check out the sway bar links for sloppiness in their joints. They should be tight. To check 'em you almost have to unhook one side of one of them to be sure there's no pressure on them.
BMR is offline   Reply With Quote
Old 06-25-2010, 12:01 AM   #4 (permalink)
Banned
i bought the strut assembly - with new mounts, springs and all.
wheel bearings are remarkable silent - none of the classic fwd "hiss" at all. believe they are in good shape...
Old 06-25-2010, 12:02 PM   #5 (permalink)
View NRecob's Photo Gallery
if you have the car up on a jack and you grab the tire at 12 o'clock and 6 o'clock positions and try and shake it up and down is it loose/sloppy? If yes, I'd definitely change the ball joints....
In any event, good luck with it.
NRecob is offline   Reply With Quote
