Continuous Fuse Blowing / Check Engine
Just curious to see if anyone has any troubleshooting/advice for this odd problem, this is on my 97 XLS...
Two days ago the AC fuse blew, which also takes out the clock, outside temperature, and stereo system. Convenient, right? (We reached a record high of 102º yesterday in Richmond, VA!) So, not really a big deal, I get a new fuse and we're good to go.
Today my check engine light comes on a little after I passed 127,000 mi, so I figure it could be a pre-programed alert and write it off in my head for a bit...
...Until I blow the same fuse again. Which I replace. And then blow again 25 minutes later. And then blow again 2hrs later. And when I finally get home for the evening I end up putting in two more just because ... why not ... and it blows them instantly.
I was told that my AC Compressor would need to get replaced "eventually". Maybe this means "eventually" is now? It works great when ... the fuse isn't blown. And has worked fine for the past 2,000/mi.
