Need help with a part name - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-09-2010, 03:24 PM   #1 (permalink)
View londonandlawson's Photo Gallery
1999 Avalon
I have been having a lot of rattling/noise coming from the back of my car when I go over bumps, make hard turns etc. I took it to a guy I know who works on cars and he said I had a bad rear strut and that the part that is circle on each side has a lot of play in it and it shouldn't. I need an exact name, he wasn't sure and gave a few options of what it might be called. The bushing are wore out on the ends I believe
lower control arm
trailing arm
I can twist that bar forward and back by hand, is this normal?
londonandlawson is offline   Reply With Quote
Old 07-09-2010, 04:35 PM   #2 (permalink)
View robcam13's Photo Gallery
rear suspension arms is what they are called. and its normal for them to to be twisted by hand. did you check the sway bar bushings?(these are a common problem) grab your rear sway bar and move it and if they are bad you will hear noises.
robcam13 is offline   Reply With Quote
Old 07-09-2010, 04:52 PM   #3 (permalink)
I have been told by two different people that these should not be able to be moved
Old 07-09-2010, 04:55 PM   #4 (permalink)
i did a google and your name appears correct. If that is normal what is causing my excessive vibration at highway speeds and my load rattling/banging noise?
Old 07-09-2010, 04:58 PM   #5 (permalink)
But then I find this and this pic looks like it and it's called a control arm
http://www.partstrain.com/store/deta...Passenger_Side
Old 07-09-2010, 06:03 PM   #6 (permalink)
well thats the same part. it is possible that it is bad that would cause a vibration.that control arm also adjusts your rear toe so you may need an alignment as well
Old 07-13-2010, 07:22 PM   #7 (permalink)
I wrench, therefore I am!
Gameroom cash: $214400
View TedL's Photo Gallery
Toyota calls it "rear suspension arm assembly #2". In conjunction with arm #1, it performs the functions of a lower control arm (which you have up front), locating the wheel laterally. But it also provides the lateral adjustment function of front tie rods (ends).
TedL is offline   Reply With Quote
