Darkish liquid in COOLANT RESERVOIR - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-13-2010, 05:31 PM   #1 (permalink)
View karl_karl's Photo Gallery
I noticed a leak underneath my engine the other day, it wasn't quite oil...kinda watery and pinkish. Then I looked at my coolant reservoir and it wasn't greek but darker and pinkish . The car isn't overheating, still accelerates normally etc. I checked the oil dipstick and the oil was light in colour, not very dark at all...about 2000 kms since last oil change but I just switched to a synthetic oil (maybe it stays lighter in colour than conventional oils)
What am I in for? Is it a bad headgasket? Cracked block? Sigh...everything else on the car is fine...
Thanks,
Karl
karl_karl is offline   Reply With Quote
Old 07-13-2010, 07:07 PM   #2 (permalink)
Banned
View The Digital MagE's Photo Gallery
i believe the factory put reddish coolant into these cars...
I am unable to understand this: "Then I looked at my coolant reservoir and it wasn't greek but darker and pinkish." GREEK?
head gaskets seldom go bad without an event - overheating, of some sort. has your car overheated recently?
if there is oil in the reservoir it will be floating on top of the coolant, not mixed into it.
The Digital MagE is offline   Reply With Quote
Old 07-14-2010, 07:53 PM   #3 (permalink)
I meant green, oops..not greek.
You are right about the factory coolant being darker...I was used to green aftermarket stuff in my other cars so the colour threw me for a loop.
Car isn't overheating...temperature gauge is always at half way.
Perhaps it's nothing at all...hopefully!
Old 07-16-2010, 01:08 AM   #4 (permalink)
Work In Progress
SyStEmOfEvIl's Avatar
View SyStEmOfEvIl's Photo Gallery
If your worried about it, flush out the system, and put new in. Then just watch if for a while and see what happends..
96 Toyota Avalon XL
SyStEmOfEvIl is offline   Reply With Quote
Old 07-16-2010, 12:52 PM   #5 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $353553
View BMR's Photo Gallery
Like Digital Mag said, Toyota uses a red coolant. So my guess is that it's a coolant leak. Does it smell kinda sweet, like antifreeze does? If it is coolant, could be the waterpump, hoses, radiator, etc. Go underneath and check it out; see if you can figure out where it's dripping from.
BMR is offline   Reply With Quote
