13 miles to gallon! 95 Avalon - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-16-2010, 03:02 PM   #1 (permalink)
View kevbeachlivin's Photo Gallery
HELP, just bought this car last month, did a full tune up, 95 avalon with 80k orig miles, documented carfax, bought from orig owner, have reciepts going way back years.
goes about 150 miles on 12 gallons. 12x13 is 156, miles.
Cheveron gas always. reg, but its not like can use prem 91 and it will get 20.
drive it easy around town, freeway around 70. never get on it, unless getting on a freeway on ramp.
what the heck is going ON.
bad cylinder? do a compression check? it runs great! at a total loss.
please help, thanks, Kevin
kevbeachlivin is offline   Reply With Quote
Old 07-16-2010, 05:11 PM   #2 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $353553
View BMR's Photo Gallery
Just couple thoughts:
Air filter changed recently?
Is the Check Engine light on?... if no, is the bulb burnt out?
BMR is offline   Reply With Quote
Old 07-16-2010, 06:39 PM   #3 (permalink)
Banned
View The Digital MagE's Photo Gallery
change the PCV valve. $4 part. then see if problem disappears.
The Digital MagE is offline   Reply With Quote
Old 07-16-2010, 08:02 PM   #4 (permalink)
Air filter new, car runs tops, very fast
Air filter new, car runs tops, very fast when I want it to, idles nice, nothing appears wrong with it, runs great. all fluids replaced, spark plugs, fuel filter. everyone that rides it in says, great running car. at a total loss of what could be.
Old 07-17-2010, 10:50 PM   #5 (permalink)
View sonic2wb's Photo Gallery
i would deff change pcv valve and then rent or buy a good obdii reader that can show you live data and see if the MAF sensor is makeing the card run rich? u can ebay a good reader on the cheap that will show live data. i have a 96 that has 199k on it now and gets 18-20 in the city and 27-29 on the interstate at 65-70mph
sonic2wb is offline   Reply With Quote
Old 07-18-2010, 10:58 AM   #6 (permalink)
Avarollin?
Jigg007's Avatar
Gameroom cash: $132150
View Jigg007's Photo Gallery
Yeah I was going to say try cooling it on the freeway if you want to squeeze some more mpgs, but 13 is way low. with 240K miles at 70mph i obtain 25mpg, but at 55 it is 35mpg
Could it be the tires or transmission related? Steers funny? rolls easy?
If it was running rich you could easily spot it in the exhaust, maybe not at idle, but if you had a friend follow you while driving for epic sniffing tests.
Click that cool picture above for my cardomain!
Jigg007 is offline   Reply With Quote
Old 07-19-2010, 03:21 PM   #7 (permalink)
View avlover's Photo Gallery
Hi;
1.May I ask you how exactly you check your mileage? Fuel gages of this car sometimes behave very erratically.
2. I would also suggest to check if you any seized brake caliper...check for any unusally hot wheel after you have driven for some time.
3. Do you see healthy check engine light during startup?
I drive 1995, 204k km, which gives me about 23mpg.
avlover
avlover is offline   Reply With Quote
Old 07-25-2010, 01:44 PM   #8 (permalink)
View bowdownmaster's Photo Gallery
try to do the seafoam treatment, that should help a bit. 1 can in half a tank of gas, half a can in brake booster and half in the oil.
bowdownmaster is offline   Reply With Quote
Old 09-16-2010, 09:10 PM   #9 (permalink)
View edge10's Photo Gallery
I know if you fix this yet, but have you checked your fuel pressure regulator for over pressure and tested your MAP sensor?
edge10 is offline   Reply With Quote
