huh? all you can do is set the toe? right, but
wrong!
using this gizmo here:
http://www.rockauto.com/catalog/moreinfo.php?pk=1023715
that you can find on this page under "suspension\alignment kit"
http://www.rockauto.com/catalog/raframecatalog.php
you can set the camber to +or- 1.4 degrees from whatever it is, now. the instructions say it may yield even more adjustment, if used in the bottom strut mounting hole.
97 camber spec is -0.62 +- .75 degrees. mine on the right was -1.5 degrees - WAY too much! now i have it down to -.3 (right) and -.5 (left) which gives me a much lighter steering feel.
the toe spec is zero degrees but i prefer about .2 degrees of toe in - makes for less wander, on the highway.
