Installing aftermarket head unit-1996 Toyota Avalon XLS - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-25-2010, 10:29 AM   #1 (permalink)
View JohnBoss's Photo Gallery
I have a 1996 Toyota Avalon XLS. I bought a sony cdx-gt640ui head unit from sonicelectronix.com and they sent the DIN kit and a wire harness, but the wire harness didn't fit. I went to Best Buy and bought the amp integration harness, and it fits but I'm installing the head unit and on the wiring harness there are 4 RCA cords and I'm confused as to where they plug into. I've removed the glove box to get to the amp but I still can't figure out where they plug in.
JohnBoss is offline   Reply With Quote
Old 07-25-2010, 12:42 PM   #2 (permalink)
Banned
View The Digital MagE's Photo Gallery
they likely do not plug in.
the rca jacks are for external amps.
The Digital MagE is offline   Reply With Quote
Old 07-25-2010, 01:44 PM   #3 (permalink)
View robcam13's Photo Gallery
they plug into the rca output on the back of the headunit
robcam13 is offline   Reply With Quote
The Following User Says Thank You to robcam13 For This Useful Post:
JohnBoss (07-25-2010)
Old 07-26-2010, 10:16 PM   #4 (permalink)
Avarollin?
Jigg007's Avatar
Gameroom cash: $132150
View Jigg007's Photo Gallery
the 6 and 7 speaker systems on the Avalon uses a factory amplifier, in order to retain that the harness plugs into that instead of directly to the speakers. This is why the harness has four RCA jacks, line level Front R+L, Rear R+L . These will plug into the "pre-amp" outputs on the back of your head unit. If your headunit only has one set of two RCA outputs, you'll have to get a two Y splitters if you want all speakers to work.
Click that cool picture above for my cardomain!
Jigg007 is offline   Reply With Quote
Old 08-02-2010, 10:26 AM   #5 (permalink)
View sonic2wb's Photo Gallery
same question here, mine car is a 96 with the double din 3 disk changer. when i had to take the unit out there where 2plugs in the wiring harness but only one was used and the other was tied back to the harness. (ill try to get a pic uploaded) do i have the factory amp system? also what size are the speakers in the doors? the drivers side is blowen and i want to replace them.
sonic2wb is offline   Reply With Quote
Old 08-02-2010, 03:29 PM   #6 (permalink)
Chunkywolf's Avatar
Gameroom cash: $144565
View Chunkywolf's Photo Gallery
The second plug is for the factory 12 disc changer. Yes, you do have an amplifier, and the stock speakers are 4".
Black 95 Avalon XLS 170k
Spectra Blue 02 Celica GT(Rolling Chassis)
2009 Kenworth T-660 (Cat c-15) 447k
Chunkywolf is offline   Reply With Quote
The Following User Says Thank You to Chunkywolf For This Useful Post:
sonic2wb (08-02-2010)
Old 08-02-2010, 03:52 PM   #7 (permalink)
Avarollin?
Jigg007's Avatar
If you replace the speakers keep in mind to disconnect the factory tweeter, if applicable.
The Following User Says Thank You to Jigg007 For This Useful Post:
Old 08-02-2010, 06:48 PM   #8 (permalink)
That leaves me with questions then lol. so i need the "amp intergration plug" setup then right?
what are some good cheap 4in speakers for the front door, im not a sound guy just annoyed at the rattleing and buzzing lol
Thanks.
Old 08-02-2010, 11:41 PM   #9 (permalink)
Avarollin?
Jigg007's Avatar
Blaupunkts are pretty cheap and have some good characteristics.
Of course, with the word cheap in mind, it all depends where you buy your product.
