there's a low pressure cutoff switch on top of the receiver/drier. it has 2 terminals. first, check to see that the thing has 2 terminals, then try the ac with the wire off. it should not work. if so, jumper the switch. your problem should vanish. if so the switch is going bad.
you can leave the jumper on BUT if its a combination switch (having high-pressure and low-pressure cutoffs in it) it will have four wires. if it has four wires, be careful. you can still jumper the low pressure cutoff but you'll need to identify the connections, first.
if you jumper the high-pressure switch the unit will run all the time and freeze the evaporator, solid.
