Stereo Help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-26-2010, 10:53 PM   #1 (permalink)
View JohnBoss's Photo Gallery
Stereo Help
First off i have a 1996 Toyota Avalon XLS.
Alright, so I've hooked everything up for my Sony CDX-GT740UI and im using the metra 70-8112 (
Amazon Amazon
Im using that and at first nothing would work, so i checked my fuses and the audio fuse was blown, it was a 15A, i replaced it with a 20A, and now when the ignition is in the off position the stereo turns on, but if i turn the key to ACC, on, or start the engine, the stereo turns off. All my fuses are good and all my wires are connected correctly. Any ideas??
JohnBoss is offline   Reply With Quote
Old 07-27-2010, 11:07 AM   #2 (permalink)
View sonic2wb's Photo Gallery
Gen1 hmm
sounds like something is not right with ur wiring? if the radio is coming on with the switch off sounds like u got the 12v constant (for keeping presets and time set) hooked to the switched 12v on the radio side. but the radio should still work no mater what key position its in. Im looking at doing this mod myself so keep us updated
sonic2wb is offline   Reply With Quote
Old 07-27-2010, 05:43 PM   #3 (permalink)
Chunkywolf's Avatar
Gameroom cash: $144565
View Chunkywolf's Photo Gallery
I'd recommend you take a multimeter and check the reading on your +ignition, if it's reading correctly, and hooked up correctly, it may be a faulty head unit. I can't really come up with any other reason as to why the stereo would be working opposite the +ignition.
Black 95 Avalon XLS 170k
Spectra Blue 02 Celica GT(Rolling Chassis)
2009 Kenworth T-660 (Cat c-15) 447k
Chunkywolf is offline   Reply With Quote
Old 07-28-2010, 05:09 PM   #4 (permalink)
Work In Progress
SyStEmOfEvIl's Avatar
View SyStEmOfEvIl's Photo Gallery
X2, there is no wire in the stereo loom that becomes charged(hot) when the key is shut off. Atleast there is not supposed to be. If there is, your ignition switch is failing or something else is wrong.
96 Toyota Avalon XL
SyStEmOfEvIl is offline   Reply With Quote
