Originally Posted by TedL
Was it empty?
Did you vacuum it?
Was the A/C running when you filled it?
Did you use a real gauge set?
If you weren't able to find the port by merely following the lines, I'm getting the sense you were working outside the extent of your knowledge.
Oh, did the refrigerant have "sealer" in it?
Ted, check out this thread. You are almost as grumpy as I am!
Charging A/C in a 98
If you don't know how to find the low side service port, you have no business messing with the AC system, period, end of discussion.
