97 Avalon loses power in HEAVY rain - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-09-2010, 03:25 PM   #1 (permalink)
rdq
View rdq's Photo Gallery
can go at most about 40 mph. It drives normal in regular rain or dry weather. Timing belt changed 30K ago. Is this likely electronic problem? If yes, what exactly?
Thanks
rdq is offline   Reply With Quote
Old 08-09-2010, 05:25 PM   #2 (permalink)
Banned
View The Digital MagE's Photo Gallery
did you (or someone) leave the right-side splash guard off the car? that would result in soaking the crankshaft sensor... which is not good for the ignition! i found that on a mazda, not a toyota, but i'm sure it will do the same thing. also, if your crankshaft sensor is cracked (or the coil is loose on the core) the rain will get inside, kinda almost shorting it out.
The Digital MagE is offline   Reply With Quote
Old 08-09-2010, 08:38 PM   #3 (permalink)
rdq
I will bring the car to a mechanic, together with your opinion. thanks!
Old 08-10-2010, 12:07 AM   #4 (permalink)
Banned
no problem, dewd... and the best thing is, my opinion comes with a money-back guarantee!
Old 08-23-2010, 09:20 PM   #5 (permalink)
View truthnexile's Photo Gallery
Yes, you most definitely have an unsound electrical connection somewhere that is exposed. This can be a pain to track down sometimes, but hopefully yours didn't turn into a huge mystery. If it starts to run that poorly it probably will be one of the main sensors. What was the verdict (assuming you took it to the mechanic)?
truthnexile is offline   Reply With Quote
Old 12-19-2010, 02:20 AM   #6 (permalink)
View fallingdown's Photo Gallery
I have the same problem on my 95. Where is the crankshaft sensor located?
fallingdown is offline   Reply With Quote
Old 12-19-2010, 07:59 PM   #7 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $281592
View csaxon's Photo Gallery
Is the air intake modified?
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 12-20-2010, 11:11 PM   #8 (permalink)
Air intake is not modified. The entire car is completely stock/OEM.
Old 12-22-2010, 08:36 AM   #9 (permalink)
Sir Loin of Beef
Jack Deth's Avatar
View Jack Deth's Photo Gallery
40 mph floored... no CEL... no misfire?
Jack Deth is offline   Reply With Quote
