a/c issues still going on. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-09-2010, 07:52 PM   #1 (permalink)
View sonic2wb's Photo Gallery
Gen1 a/c issues still going on.
OK to rehash an old topic here.
a/c had random issue of not coming on and the light blinking. press the button a few times it will come on.
When it works it works good. very cold.
OK new issues:
idleing at a redlight for a good bit will cause it to kick off. wait for the light to turn green and once going it press button it will work again.
sometimes on short trips 5-10miles it will work till u cut car off and come back it sometimes wont come on.
I have a low side gauge and its reading 45psi at about 87F degrees which is right according to what i have read. so Im starting to think its either one of the preasure switchs or someone mentioned theres a clutch lock up sensor.
Im annoyed at this because i want to install a remote start system but there no point unless i know the a/c will come on!
sonic2wb is offline   Reply With Quote
Old 08-10-2010, 12:11 AM   #2 (permalink)
Banned
View The Digital MagE's Photo Gallery
locate the low-pressure cutoff switch. short it out with a jumper wire. see if the problem disappears. if so, change the switch.
if not, repeat for the high-pressure switch.
if not (gulp) you're probably looking at an expansion valve
The Digital MagE is offline   Reply With Quote
