My 98 Avalon water/leak issue
I have a 1998 Avalon XL with sunroof/moonroof.
Problem #1:
Whenever it rains, the rear door on the driver side seems to have water drain INTO the door. When you swing the door open or close you can hear water in it. To drain it, I basically have to rip the rubber piece at the bottom of the door.
Also, when I was checking my spare tire in the trunk, there was a little water in there too. Yesterday when I was getting the car jack and i noticed a clear tube in the same compartment. I have a feeling that this is somehow causing water to flow into the trunk. That is just my thought, anyone have any idea?
I got my hose out to spray water all over the car for about 10 minutes, and water didn't get in the door or my trunk. However, this only seems to be an issue when it rains.
Problem #2
I was told by a mechanic that my shocks and struts need replacement. But when I took it to the dealership for them to look at it, the first thing they told me was that "it is not a safety hazard, so it would be fine if you choose not to replace it...". They didn't even bother looking at it. What do you guys think? Should I spend about $800 to get this replaced? Or should I just leave it as it is because it "isn't a safety hazard" ?
