Just inherited a 98 Avalon with 107k miles on it from my dad. Suspension is too bouncy - but not unsafe, probably shot from hauling 5 people and gear. Want to fix this and improve suspension/handling, but not lower the suspension at all. I'm pretty dead set on that.
Do the struts and/or springs need to be replaced?
What are my options?
Any brands?
Approximately what is the price range this should cost?
Yes, chances are you need a new suspension. Many manufacturers recommend replacing shocks/struts/springs every 50,000 miles.
You can go with a Vogtland Sport Suspension but that lowers your car close to 2 inches.
KYB makes their Excel-G line for Avalons
Monroe makes both their Monro-Matic and Sensa-Trac for Avalons
Gabriel has a preassembled set for Avalons.
If you don't want it lowered you might want to go with KYB. They tend to be a bit stiffer (from what I've heard). Sensa-Trac and Monro-Matic tend to be more of an OEM feel with Sensa-trac having a better overall performance. I believe Gabriels are also an OEM feel.
It will cost anywhere from 500ish to 800ish dollars if you do it yourself and 700 or more if you have them done for you.
Poke around, do some research. Most manufacturer websites will have car searches that let you put in your car and they will give you your options.
The Following 2 Users Say Thank You to jbfrench For This Useful Post:
when doing the struts, keep in mind that the strut mounts may be bad. I would recommend at least looking at them, and since the struts have to come out, if they haven't been replaced, you may want to consider them.
As for the springs, have them inspected. Metal, as you know, isn't the most elastic of all materials. If it has a little less than 1000 pounds pushing down on it constantly and much much more every once and while, chances are it will shrink. Your coil springs could be a 1/4" shorter, 1/2" or more. Have them inspected, ask several shops if you should replace the springs.
Also, remember that these springs are roughly the same as the ones that come on 98 Camrys which weigh around 3000 pounds. Depending on your options an Avalon could weigh nearly 3500 pounds without you even being in it. Thats a lot of extra strain, specially over 107k.
But, if you don't need them, I can't particularly recommend getting them. If you aren't bottoming out or dipping when you take turns then you should be fine. Like I said, have them checked.
The Following User Says Thank You to jbfrench For This Useful Post:
I'd just get some quick struts from Monroe or Gabriel. You can get the best deals from rockauto or amazon. This replaces the strut, strut mount, spring, and upper and lower rubber spring seats. Just unbolt the old strut, and install the new one, no springs to compress. KYB might be a good strut, but you pay a lot more if you need to replace the strut mounts on top of the strut and you have to change out the spring which may be worn out.
I'm planning on doing this to my 98 in the near future and thought I would share my research.
At 107k, do yourself a big favor and replace the strut mounts and strut bearings (on front). If they haven't failed yet they will very soon. Use Toyota factory parts. KYB mounts are pure crap. Moog may be ok but they cost almost as much as factory. KYB struts are OEM and are very high quality. The bottom rubber insulators will be shot and are very expensive for what they are. I used an 18" length of vinyl tubing snaked onto the coil spring. Got the idea from LexMex over on the ClubLexus forum. Works like a dream.
The Following User Says Thank You to artbuc For This Useful Post:
If you do go OEM, remember that I offer TN members a 30% discount off MSRP. I only charge actual shipping costs plus a $1.00 - $2.00 for materials, etc.
Whatever route you do decide on, good luck. If you need anything, let me know, even if it isn't parts related, Im in here to assist the members in anyway I can.
At the moment, I sell only genuine Toyota OEM parts. I am a factory authorized Toyota Dealer. If you are looking for an alternative, I'd say KYB is a decent shock. I honestly don't know who manufactures them for Toyota, it could be KYB, but I really don't know.
Originally Posted by zaner123
Toyota man, what can you order for us? Toyota brand struts only or? Thanks
Digital MagE, I don't mean to argue, but Amazon is offering Monroe quick struts for our cars. I compared the part number against the part number from Monroe's website and it's the same number. They just added a "1" in front of the part number to indicate it is a quick strut.
The springs almost never need to be replaced. If anything you will want to look at replacing the spring isolators. They are the rubber that the springs sit on when the shock absorber is put in place. These cost me $20.00 each. You can get them from Toyota only.
Another option you want to consider is the Shock absorber boot cover. You can get these for about $15.00 or less per cover on ebay.
The Following User Says Thank You to GOT BOOST For This Useful Post:
