99 Avalon Shift Lock Override Button Failure - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-25-2010, 08:42 AM   #1 (permalink)
View jotaka20's Photo Gallery
Okay so as stated I have a 1999 Avalon with an automatic transmission. The selector is stuck in the park position. I have simply tried to depress the brake and shift, use the shift lock override button without and with the parking brake on. Is there any solution to even get the car moving to get it to a dealer or shop? Or even a quick fix check to see what the problem could be?
jotaka20 is offline   Reply With Quote
Old 08-25-2010, 11:39 AM   #2 (permalink)
I wrench, therefore I am!
Gameroom cash: $214400
View TedL's Photo Gallery
You mentioned the override button, so you know the procedure shown in the owner's manual to deal with the problem.
Are you parked on a slope?
TedL is offline   Reply With Quote
Old 08-25-2010, 11:58 AM   #3 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $281592
View csaxon's Photo Gallery
STOP LIGHT SWITCH UNDER DASH MAY NEED ADJUSTING OR IS DEFECTIVE.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 08-25-2010, 05:35 PM   #4 (permalink)
Avarollin?
Jigg007's Avatar
Gameroom cash: $132150
View Jigg007's Photo Gallery
Indeed, do your brake lights work? Also, when in park and the ignition on, when the brake is depressed a noticeable (for me atleast) click is heard. Fuse, relay, possible problems. Try wiggling wires under the dash! (I'm super crazy, I know!)
Isnt there a location on the bottom of the transmission to pop the car into neutral? Not sure if this will help though!
Click that cool picture above for my cardomain!
Jigg007 is offline   Reply With Quote
Old 08-25-2010, 06:00 PM   #5 (permalink)
View robcam13's Photo Gallery
u can unhook the cable at the tranny and manually put it in neutral. there is a fuse that controlls your issue. not sure what one but its under the hood. i had a land cruiser do the same thing. also are you sure you are pressing the override button all the way cause that should work to shift gears even with a bad fuse.
robcam13 is offline   Reply With Quote
