estimated repair cost - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-26-2010, 05:56 PM   #1 (permalink)
View mistersink's Photo Gallery
i have a 97 with a bad O2 sensor (bank1 sensor2 after cat converter) and also there is a leak in the exhaust where the flanged pipes connect just after the cat converter. This exhaust leak was repaired not too long ago, but apparently the last guys did a poor job. How much can i expect to pay for these repairs? Also, I just moved and don't know any local mechanics; what chains are the best for this sort of thing? Is Meineke good?
Thanks.
97 Toyota Avalon XLS V6
mistersink is offline   Reply With Quote
Old 08-26-2010, 06:41 PM   #2 (permalink)
I wrench, therefore I am!
Gameroom cash: $214400
View TedL's Photo Gallery
The cost s/b somewhere between $20 and $2500, depending what parts need replacement and who does the work. The high end will be a Toyota dealer installing new front and center pipes.
I also believe you've misplaced the sensor. Bank 1 is on the engine, bank 2 would be the post cat, and there's only one post cat sensor.
TedL is offline   Reply With Quote
Old 08-26-2010, 06:50 PM   #3 (permalink)
it's the one post cat. thanks.
Old 08-26-2010, 07:18 PM   #4 (permalink)
Banned
View The Digital MagE's Photo Gallery
just cut the flange out of the pipe then replace it with a new piece of solid pipe. muffler shop - about $40 or so. disconnect battery, hold brake down for a minute to clear codes. repairing the exhaust leak will probably fix the o2 sensor code, as well.
The Digital MagE is offline   Reply With Quote
