Belt Squealing...Help. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-06-2010, 01:50 AM   #1 (permalink)
Avy
Gameroom cash: $821455
View pmesfun's Photo Gallery
Gen1 Belt Squealing...Help.
Whenever I start the engine when cold and the A/C is on or I turn it on after I start the car, the belt squeales for a good 5-10 seconds. It never squeals when I turn on the A/C once the engine is warm. It started squealing about two months ago. I just replaced both belts on Friday with Dayco brand. Problem still exists after new belts. Any suggestions?
Thanks!
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is online now   Reply With Quote
Old 09-06-2010, 09:34 AM   #2 (permalink)
View sonic2wb's Photo Gallery
i have the same issue when i replaced the belts on my car u could try tighting it up a bit
sonic2wb is offline   Reply With Quote
Old 09-06-2010, 10:57 AM   #3 (permalink)
Banned
View The Digital MagE's Photo Gallery
loosen the lock bolt. turn the tensioner bolt 1 turn, clockwise. if squealing persists, repeat
The Digital MagE is offline   Reply With Quote
Old 09-06-2010, 01:41 PM   #4 (permalink)
Avy
Gen1
Tightened both belts, they were loose. The power steering was a pain though, I had to hold the bolt in place because it wanted to go back to the top. But so far no squealing.
Thanks, Guys!
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 09-06-2010, 02:08 PM   #5 (permalink)
CTB727's Avatar
Gameroom cash: $588035
View CTB727's Photo Gallery
Hm, I have a similar problem, except my belts only squeal if i drive through a puddle too quickly. Now I just do my best to avoid them. Maybe they need tightening as well..
1999 Toyota Avalon XLS
2006 Toyota Tundra Double Cab X-SP
2010 Lexus ES350 w/ Nav package
Originally Posted by rty View Post
Six Camrys, one from each generation. In a temperature controlled alarm secured garage filled with Camry memorabilia. I just worry I might not be able to enjoy every Camry. So many Camrys so little time.
CTB727 is offline   Reply With Quote
Old 09-06-2010, 05:42 PM   #6 (permalink)
Avy
^Sounds like one of your splash guards in that area are loose, check and see if you see anything. I had that same problem on my old van and the splash guard was the problem.
99 Avalon XLS-149k
99 Lexus LS400-88k
