Originally Posted by edge10
Actually 23K miles is correct, this is a car this gets driven mostly short trips by a retired person. I found in the Toyota online maintenance they recommend 90K miles or 72 months which ever comes first. This is not in the printed manual in the car, though. Online I also recall they stated to inspect the belt at the 72 month interval and decide to change the belt if worn, but I also found that with some belts (EPDM?) you can't tell wear by typical inspection.
I will say shove the Toyota recommendation. Toyota has a
Non-interference engine. If it breaks, then change it. However, findout where to get parts & what make to use. Belt was Mitsuboshi, Idlers were Koyo & , Water pump was Aisin. These are the names I found on the Original parts.
I changed my 1999 only last year after 140K miles.
