97 to 95 engine swap,is it possible? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-14-2010, 05:27 PM   #1 (permalink)
View Avy4eva's Photo Gallery
Hey guys this is my first post here, and was wondering if you guys could shed some light for me. I have a 1995 Toyota Avalon with a dead engine. It has bench seating with the column shifter. I went to the junk yard looking for another engine and they told me a I need an engine with Californian emission specs. Not quite sure what that means, but I happened to wreck my other 1997 avalon :-( I was wondering if a swap was possible and if it would work. Please guys hel me out because Im trying to do this soon.
Avy4eva is offline   Reply With Quote
Old 09-15-2010, 01:20 AM   #2 (permalink)
Chunkywolf's Avatar
Gameroom cash: $144565
View Chunkywolf's Photo Gallery
If you bring over ALL the parts from the 97(engine/ecu/cat/etc) to the 95, it should work out fine. The CA mention is saying that if you are swapping only the engine itself, you need a CA engine since your ECU and all are programmed and designed for CA specs.
Black 95 Avalon XLS 170k
Spectra Blue 02 Celica GT(Rolling Chassis)
2009 Kenworth T-660 (Cat c-15) 447k
Chunkywolf is offline   Reply With Quote
Old 09-15-2010, 01:44 AM   #3 (permalink)
View CWH5's Photo Gallery
Remove both engines and install the exhaust manifolds with A/F sensors, upper intake with throttle body from the 95 to the 97 engine, Install engine and call it a day.
Toyota MDT,ASE Master/L1,DEQ CRT
92 & 93 Camry 5s-fe
00 Sianna XLE, 03 Prius
89 Trans-Am
69 Camaro RS/SS
CWH5 is offline   Reply With Quote
