'96 avalon starting issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-25-2010, 02:21 PM   #1 (permalink)
View Brown Bear's Photo Gallery
Question '96 avalon starting issue
Hello All,
My wife told me that her Avalon has a "problem starting." Hmm, okay, I go to check it out.
I put the key in and the engine cranked slowly at first for a few seconds so I backed the key off. I started the car again and it cranked normally.
The first thing I did was to check the battery terminals. So I took them off the posts and wire brushed them, cleaned and retightened the posts. I then had the battery tested and it showed good (only 14 months old) with 13 volts and all the cranking amps, still.
I thought that took care of it, but she said the car was having problems starting still a few weeks later. Hmm, I checked it out again. This time I put the key in and nothing happened. I tried again and it cranked okay.
My question is how to determine whether the solenoid is going bad or if it might be the ignition itself. Can the starter be taken off and bench tested?
Any help will be greatly appreciated,
Jack
Brown Bear is offline   Reply With Quote
Old 09-25-2010, 02:38 PM   #2 (permalink)
30YRTOYOTAPARTSEXPERINCE
TOYOPARTSMAN's Avatar
Gameroom cash: $327600
iTrader Score: 12 reviews
View TOYOPARTSMAN's Photo Gallery
Yes, it can be. But if you go that far, my suggestiong is to put a set of contacts in. That is what usually wears on those starters. OEM part# 28226-64370 and 28226-74070. One positive lead, one negative lead.
Gary Smith-Parts Manager
garys@toyotaofnewnan.com
www.ToyotaofNewnan.com
678-854-9601
TOYOPARTSMAN is offline   Reply With Quote
Old 09-25-2010, 05:52 PM   #3 (permalink)
Gameroom cash: $301725
View artbuc's Photo Gallery
Originally Posted by Brown Bear View Post
Hello All,
Jack
Aftermarket contacts are more than adequate and can be had for $15 or so. Pretty easy to install.
PS Good practice to replace the plunger too. Not usually necessary but it is fairly cheap and gives you a good feeling to know you are getting solid contact.
http://www.nationsautoelectric.com/densoparts.html
artbuc is offline   Reply With Quote
