need help for a shaking 97 avlon - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-27-2010, 01:01 PM   #1 (permalink)
View ly2340's Photo Gallery
Wink need help for a shaking 97 avlon
hi to all ur expert.
i've got a problem with my 97 avalon [401000km] ,i replaced 2 knock sensors,new spark plugs 2 mths ago,now i get a code p0446.here is the problem,while i was driving few days after replacing knock sensors,the car suddenly shaking like crazy for a minute or 2,[it never happened before],so i change trany fluid [got from dealer],for 2 wks it's very smooth.this morning,the shaking happened again for about 2 -3 minutes,i had to stop the car.then i scaned after came home,there is no other code ,only p0446.does anyone have any idea about this problem?will that relate to the knock sensors,or spark plug [i use the single ground instead of double.i had the single ground all the time],any suggestion would be very appreciate
ly2340 is offline   Reply With Quote
Old 10-27-2010, 02:10 PM   #2 (permalink)
Sir Loin of Beef
Jack Deth's Avatar
View Jack Deth's Photo Gallery
just a shot in the dark... maybe an intermittent coil.
Jack Deth is offline   Reply With Quote
The Following User Says Thank You to Jack Deth For This Useful Post:
ly2340 (10-28-2010)
Old 10-27-2010, 08:58 PM   #3 (permalink)
View GOT BOOST's Photo Gallery
Here you go!
http://www.obd-codes.com/p0446
GOT BOOST is offline   Reply With Quote
Old 10-28-2010, 07:43 AM   #4 (permalink)
Originally Posted by GOT BOOST View Post
thanks for the link.but i just worry about the Shaking,any other suggestion?thanks
Old 10-28-2010, 09:07 AM   #5 (permalink)
Let me out of my cage....
HATEnFATE's Avatar
Gameroom cash: $163450
View HATEnFATE's Photo Gallery
Do you feel like you lose power when the shaking starts?
"Fools", said I, "You do not know, silence like a cancer grows.
Hear my words that I might teach you. Take my arms that I might reach you"
But my words, like silent raindrops fell, and echoed, in the wells of silence.....
Jason Johnston
Toyota/Scion of Des Moines
(800)342-7045
HATEnFATE is offline   Reply With Quote
Old 10-28-2010, 03:17 PM   #6 (permalink)
that's right,it seemed like no power at all
Old 10-29-2010, 11:05 AM   #7 (permalink)
Look for vacume leaks around where the code is centred.
The Following User Says Thank You to GOT BOOST For This Useful Post:
ly2340 (10-29-2010)
Old 10-29-2010, 02:05 PM   #8 (permalink)
HATEnFATE's Avatar
If you're also losing power, i'd look at a few diff things.
Check your throttle body. It might need to be cleaned. Mine was nasty and because of the gunk, it would stick a little when it was raining or really humid and cause a similar issue to what you're having. It would even stall every now and then.
Check your ignition componants. Get OE, Dual ground plugs for your car if you're not running them. You might have a coil going bad. If a coil goes, you lose 2 cylinders and your car will run like crap.
Jason Johnston
(800)342-7045
The Following User Says Thank You to HATEnFATE For This Useful Post:
ly2340 (11-02-2010)
Old 10-29-2010, 03:11 PM   #9 (permalink)
If you lose a coil there will be a code of misfire detected in cyl # XX.
I agree on the throttle body clean and check the grounding. If it is stumbling I would check for vacume leaks related to the error code first. Vacume leaks can wreak havoc on OBDII Equiped vehicles.
ly2340 (11-02-2010)
