Need Help Guys!!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-08-2010, 08:48 PM   #1 (permalink)
Avy
Gameroom cash: $821455
View pmesfun's Photo Gallery
Need Help Guys!!!!
Today I purchased a new thermostat, gasket and coolant from my local Toyota dealership. While I was looking at the FSM it says that you need to replaced the O-Ring on the Water Inlet Pipe. On the dealer's parts website they don't even have a o-ring listed under the cooling->water inlet section.
Well, I finally found it on their website(it was listed in the wrong section). Would it be okay to use the original o-ring?
Thanks Guys
Here is where it's noted in the FSM:
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is online now   Reply With Quote
Old 11-08-2010, 09:28 PM   #2 (permalink)
Tech1984's Avatar
Gameroom cash: $256350
View Tech1984's Photo Gallery
Go ahead and reuse, but keep a close eye on that area for leaks after all the disturbed parts are back together and running.
I like to put Syl-Glide on all my orings and seals when reassembling.
Tech1984 is offline   Reply With Quote
The Following User Says Thank You to Tech1984 For This Useful Post:
pmesfun (11-08-2010)
Old 11-09-2010, 12:03 PM   #3 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $281592
View csaxon's Photo Gallery
Get a new o-ring. Do the job right the first time.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 11-09-2010, 12:06 PM   #4 (permalink)
Avy
I managed to replace the thermostat without disconnecting the inlet pipe from the housing. Finally my cooling problem and fixed, and MPG will go back to normal.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 11-09-2010, 12:09 PM   #5 (permalink)
30 yrs of Car Photography
hairball's Avatar
View hairball's Photo Gallery
Thumbs up
Precisely!
By the way, "Hairball" was a cat of mine.
Since I don't use the "GameRoom", can you just send me a check?
hairball is offline   Reply With Quote
Old 11-09-2010, 02:35 PM   #6 (permalink)
Avy
There was no need for it, because I didn't separate that inlet pipe from the housing.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 11-10-2010, 07:15 PM   #7 (permalink)
Avy
Great, now my power steering pump is leaking. Would it be better to change it, or buy the seal kit from Toyota. It seemed to work fine, but there is a faint whine, (when turning wheel in both directions, seems normal) at idle. Any suggestions
Thanks
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 11-10-2010, 11:22 PM   #8 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $354053
View BMR's Photo Gallery
Is the fluid level OK? My Avalon has a slow leak, and it'll whine if I let it get too low.
BMR is offline   Reply With Quote
Old 11-11-2010, 12:11 AM   #9 (permalink)
Avy
The fluid level is actually almost full. I will take a look at it again in auto tech, and find out what the problem is.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 11-11-2010, 12:09 PM   #10 (permalink)
virotek's Avatar
View virotek's Photo Gallery
Hmm, I should check the fluid level on mine. Now that the mornings have gotten colder, I'm getting a bit of a whine when I'm turning/backing off the driveway.
Family Maintenance List:
'93 Blue 240SX (127k mi.) SR20DET(~70k mi.) | '99 Diamond White Pearl Avalon XLS (134k mi.)
'01 Rav4
| '07 Voodoo Blue FJ Cruiser | '07 LS460
virotek is offline   Reply With Quote
Old 11-11-2010, 02:59 PM   #11 (permalink)
Avy
^I have a whine also, but it has been doing that for as long as I can remember. I'm pretty sure its normal.
So, in auto tech today I determined that the power steering pump is actually leaking and the rear valve cover gasket is seeping also. I am going to get the seal kit and try to rebuild the pump.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 11-11-2010, 03:17 PM   #12 (permalink)
30YRTOYOTAPARTSEXPERINCE
TOYOPARTSMAN's Avatar
Gameroom cash: $327600
iTrader Score: 12 reviews
View TOYOPARTSMAN's Photo Gallery
When doing that, check the shaft on P/S PUMP. Make sure you use a factory kit; part number 04446-06040 and the shaft number is 44312-06010. kIT IS $32.48 MSRP and the shaft is $16.83 MSRP.
Good luck.
p.s. Can't believe you bought elswhere
So, in auto tech today I determined that the power steering pump is actually leaking ad the rear valve cover gasket is seeping also. I am going to get the seal kit and try to rebuild the pump.
Gary Smith-Parts Manager
garys@toyotaofnewnan.com
www.ToyotaofNewnan.com
678-854-9601
TOYOPARTSMAN is offline   Reply With Quote
Old 11-11-2010, 03:29 PM   #13 (permalink)
Avy
Good luck.
Well the price turned out be the same, and I needed the parts the next day. Anytime else, I will for sure order from you.
I'm about to send you a PM.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 11-11-2010, 03:37 PM   #14 (permalink)
I know and understand. I was just making it light and fun.
678-854-9601
Old 11-11-2010, 03:38 PM   #15 (permalink)
Avy
, ok
99 Avalon XLS-149k
99 Lexus LS400-88k
