Originally Posted by avalonian98
i measured my front sway bar bushings with a set of calipers and from what i recall, they were 18mm....and i have a 98 avalon xls. don't take this as gospel because it was a few months ago and my memory fails me from time to time.
jigg.......above, you mentioned all the suspension work you've done yet you have so many regrets. let me ask you, if you had to do it all over, what would you do different?/? please, from your experience, what specific struts, mounts, springs....links, bushings, etc. would you purchase/install??? why?
my 98 has rattling issues (front) and the suspension seems pretty soft when performing a bounce test. even though i had the rear struts replaced just a thousand miles ago, i can tell you if a few fata**es like me got in the back seat, the struts/springs would likely bottom out over moderate bumps. no, i didn't replace the springs in the rear as the car only has 55k miles. regardless, the new rear struts did help and NOW i'm on to the front end to address the rattles...poor ride/handling. wish i knew what brand replacement struts and mounts would give the best results....without lowering. also i'm in need of s.b. bushings and end links....while i'm at it.
Heres a list I keep of my repairs. For the sake of simplicity i removed tire rotations/oil changes.
1996 Toyota Avalon XLS
VIN# 4T1Bf12B7TU06xxxx
Purchased February 2007
195K - New valve cover gasket
New Spark Plugs "Bosch Platnum"
New Spark Plug wires
New front and rear brake pads
New front and rear rotars
New battery "Optima YellowTop"
210K - New Fuel Injector, cylinder 3 "BWD"
Replace Coil pack on cylinder 3 "Toyota OEM"
Oil Change
216K - Two Fuel Injectors, cylinders 1 & 5 "BWD"
New timing belt kit "Toyota"
New Water pump "BWD"
New accessory and ps pump belt "Gatorback"
Replaced cam seals
Coolant Flush
220K - Replaced Front and Rear Struts "KYB"
Replaced Front and Rear Strut Mounts "OEM"
Replaced front and rear coil springs "Moog"
Replaced rear adjustable/turnbuckle lateral links "Toyota OEM"
"Seafoamed" Engine (Oil, Intake, Gas)
Oil Change
225K - 4 New tires "Goodyear Assurance Trippletread"
Oil Change
233K - Rotate tires
4 Wheel Alignment
243K - Clean EGR
Clean Throttle Body
Replace fuel filter "Fram"
Replace Right Control Arm and ball joint "Napa"
Replace Rear non adjustable latteral link "Toyota"
Replace rear sway bar bushings "Moog"
240K - 12/05/2010
Right now I have a CEL for a P0330, Rear bank knock circuit. Not sure if that means theres noticeable knocks by the computers standards, or the sensor is failing. (I swear, fix one thing, and another thing breaks!)
What eats me up now is that about 4 months ago I brought my Avalon into a Toyota dealership for a transmission flush. They said the fluid was still red and they wouldnt recomend changing it for another year. Cool, I thought, save my self $150 for the time being. I brought it back a couple days ago and am told that the fluid is dirty, and its "the glue holding the transmission together". They refuse to change it. It bothers me that something as simple as a dirty fluid that I cannot change will be the death of my car. (unless in whatever time it takes the tranny to fail i can find a cheap one and persuade myself and my father to change it, longshot!)
When I said "I regret" I meant the fact that I went with kyb struts and moog coils (big $$$) and cheaped out on the mounts.
"I just cant get rid of it because it needs a $100 part!" Too bad I've said something like that over two dozen times. Being attached to things suck. I love driving the car and it looks damn good while doing so.
I'm done raving like a lunatic, I swear!
