Please Help - CEL Trouble Code P0304 on 1996 Avalon - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-01-2010, 11:47 PM   #1 (permalink)
View HeaVyMetal's Photo Gallery
Hi all I am new to the YodaNation and have and issue leaving me
My wife has 1996 Avalon that recently had a flex pipe replaced, which I assume the misfiring engine caused the weak flex pipe to go pop. At the time I figured the CEL was on due to O2 sensors not getting the proper readings due to the lack of exhaust. Also figured that the major exhaust leak tha was directly under the engine made it seem like it was idling & driving rough. I learned that after the flex pipe was replaced by the exhaust shop that I was wrong. It was still running rough & the check engine light was still on, but hey at least it is quiet about it now .
The OBD II scanner is only pulling one code: P0304 aka Cylinder #4 Misfire. Even though the spark plugs were changed 10K miles ago. I swapped #4's SP with a new one, but without any improvement. So, I tested the resistance of cylinder #4 ignition coil. All was within spec with the primary coil testing at 0.8 ohms; secondary coil testing at 13K ohms. I decided to swap the coil from cylinder #6, JIC. At first it was running smoothly until 3 minutes into the test drive then back to it went. Clear the code, I was hoping for a cylinder 6 code that way I could blame the coil & be done with it. Instead it was still P0304.
Any ideas or suggestions are greatly appreciated. Thanks in advance.
HeaVyMetal is offline   Reply With Quote
Old 12-02-2010, 09:27 AM   #2 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $281592
View csaxon's Photo Gallery
What did the removed plug look like? Check the spark plug wire or maybe a fouled fuel injector. Try some Techron in the fuel and see if it improves.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 12-02-2010, 09:28 AM   #3 (permalink)
tacosteelersman's Avatar
Gameroom cash: $170177
View tacosteelersman's Photo Gallery
Possible bad injector
95.5 Tacoma 2.7 300,000
91 Corolla 1.6 180,000
96 Avalon 3.0 190,000
95 Ford Aspire 1.3 125,000
tacosteelersman is offline   Reply With Quote
The Following User Says Thank You to tacosteelersman For This Useful Post:
HeaVyMetal (02-27-2011)
Old 12-02-2010, 11:30 AM   #4 (permalink)
Sir Loin of Beef
Jack Deth's Avatar
View Jack Deth's Photo Gallery
pardon me for being ignorant (my last car had a distributor), but what causes the coil to fire? just guessing, a 12V signal? maybe the 12V wire is bad.
Jack Deth is offline   Reply With Quote
Old 12-02-2010, 04:39 PM   #5 (permalink)
Here is a the best pic I could get of the spark plug.
Old 12-02-2010, 05:00 PM   #6 (permalink)
Also, as far as Techron is concerned is there a major difference between that & SeaFoam. The reason I ask is before I changed the replaced the valve cover gasket, spark plug seals, spark plugs, cleaned the throttle body, & changed the oil this last spring. I seafoamed everything... added to crank case, added to fuel tank, & drove around for about a week (60 -80 miles). Then, slowly poured into the vacuum line, turned over, let sit, & finally sat back & watched smoke show. Everything has been smooth operating since then. Also, is there a method to test the injector if so what's the process?
Old 12-03-2010, 10:56 AM   #7 (permalink)
Thanks to everyone for the suggestions so far. Sorry haven't had a chance to trouble shoot more since I was doing the wheel & spindle bearings on my truck last night. Once I get some time I will check the 12v signal at the coil. If that's good I will pull the #4 & #6 fuel injectors, clean them, and swap them. If that doesn't fix it or last move the misfiring cylinder to #6 so I can at least blame the injector. I don't know where else to look, but I will keep everyone posted on what I find.
Old 12-03-2010, 04:02 PM   #8 (permalink)
The plug doesn't look bad. I prefer pure Techron for cleaning the injectors on the car. The Toyota product is repackaged Techron.
The Following User Says Thank You to csaxon For This Useful Post:
Old 02-27-2011, 12:13 PM   #9 (permalink)
Thanks again to everyone for their input. I found out the problem back in December, but I fell into my own pet peve of not posting the final resolution & closing up the post. The injector was in fact bad, I tested it's resistance & discovered it didn't have any.
Old 02-27-2011, 12:25 PM   #10 (permalink)
Great! Thanks for the feedback.
Tags
avalon, cel, generation 1, misfire, p0304
